Comando
https://www.summitracing.com/int/parts/cca-61-244-4/recommendedparts/part-type/timing-gears
Tuchos
https://www.summitracing.com/int/parts/cca-813-12
Engrenagens:
https://www.summitracing.com/int/parts/cca-3211/overview/
To com duvida, pois o comando e para utilizar com tubos hidráulicos....Sera que fica bom? Ou e melhor ir para um 250-s da Kuir?
