Seguinte galera to querendo montar um negócio razoável no meu coupe o Cd eu já tenho assim como as 2 D-250X, mas no caso de apenas 1 Sub eu vou usar apenas uma D-250X seguem os itens
Meu cd Premier DEH-P880PRS
Especificações
Supertuner (AM/FM Radio)
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
Satellite Radio Capability
XM Radio Ready Yes (GEX-P920XM Required)
Sirius Radio Ready Yes (SIR-PNR2 Required)
CD Player
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
iPod Control Capability
iPod Control Capability Adapter (CD-IB100II required)
Additional System Expandability
IP-Bus System Control
Multi-CD Control
DVD Control
TV Tuner Control
Display Output
Built-in Auxiliary Input Built-In (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Motorization Auto Slide Motorized
Display Type White Organic EL (OEL)
Dot Matrix OEL Size 160 x 48
Multi-Language English, French, Spanish
Button (Key) Illumination Switchable Blue or White
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer Dual (L/R) 16-Band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features
Volume Control Rotary Volume
Operation Mode Rotary Commander
BRAVOX CS60U
OU DA MTX
ESPECIFICAÇÃO
Kicker Modelo CVR12 400RMS
Tamanho (pol, CM) 12, 30,5
Impedância (OHMS) 2 ou 4 DVC
Rec. Amplificador Max Power (WATTS PEAK / RMS) * 800/400
Sensibilidade (1W/1m dB) 86,7
Resposta de Freqüência (Hz) 25-500
Profundidade de montagem (pol., CM) 6 5 / 16, 16,1
Mounting Cutout (pol., CM) 11 1 / 8, 28,3
Min Rec. Sealed Box Volume (cu. FT., Litros) 1, 28,3
Max Rec. Sealed Box Volume (cu. FT., Litros) 4,6, 130
Min Rec. Vented box volume (cu. ft., Litros) ** 1,75, 49,6
Max Volume Rec. Vented Box (cu. ft., Litros) ** 2,25, 63,7
ESPECIFICAÇÕES
MTX SUB TR5512-04 400 RMS
Cone de polipropileno
Costurados nitrile-butileno borracha surround
Carimbada aço cesta
Poder manipulação: 200-400 watts RMS
Potência de pico manipulação: 800 watts
Sensibilidade: 86,6 dB
Top-mount profundidade: 6-3/4 "
Caixa selada volume: 1.25 cu. ft
Portado Volume: 2.0 cu. ft
ESPECIFICAÇÂO
# Tamanho 12"
# Potencia Max: 1400 W
# Potencia Nominal: 400 W
# Cone IMPP reforçado de fibras entrelaçadas de basalto/carbono para baixos mais natural
# Bobina de voz longa de 4 camadas de cobre
# Borda radial com rolo largo de três camadas (2 camadas de urethane com uma camada de fibra interligada entre eles)
# Imã poderoso de massa duplo (83oz) para mais força magnética e música maior e mais exata
# Bobina de Voz de vidro revestiu de phenol resin
# Conjunto magnético com pólo estendido e ventilado
# Abafador de Fibras de Aramid
# Cesta selada com cobertura para o ímã
# Terminais de Compressão prateados de um só lado integrados
ESSE MÓDULO PARA O SUB
ESPECIFICAÇÃO
ESPECIFICAÇÕES
Seguem os Preços em DOLAR
Subs
CVR12-4DVC 90.00
TR5512-04 115.00
TSW 308D2 63.00
MODULO SSL F4-400 400W 4CHANEEL 38,30
MODULO SSL F1200M 1200W DIGITAL 59,47
Agora é que começa minhas dúvidas quero um sub pra muito grave sei que os MTX são excelentes para Sub Gave só que o preço está acima dos Kickers, e o Pionner tá compreço excelente dá até pra colocar 2 ao invés de um MTX ou o Kicker e tambem aproveitaria pra colocar minha outra corneta que vai ficar parada, só que teria que partir pra um outro módulo cado montasse para 2 subs,agora fiquei impressionado com esse video sendo que os falantes Sony não são muito bons para grave mas esse me surpreendeu e muito
gostaria da opinião da galera sobre meu projeto
Especificações
CD Player
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
Max Directory 8
Max. Folder # 99
File Name 64 bytes
Tag Length 64 bytes
Tag Display On/Off
Multi-CD Control
DVD Control
TV Tuner Control
Display Output
Display Features
Face Type Flap Face
Audio Features
Equalizer Presets 5
Loudness Yes
DSP
Auto-Time Alignment
BBE Digital
General Features
BRAVOX CS60U
OU DA MTX
ESPECIFICAÇÃO
ESPECIFICAÇÕES
Carimbada aço cesta
ESPECIFICAÇÂO
# Tamanho 12"
ESPECIFICAÇÃO
- 1200W Monoblock Amplifier, High/Low X-over, Remote Sub Level Control
- 2 Ohm Stable Mono-Block
- Variable low pass crossover: 40-150Hz
- Fixed high pass crossover (200Hz)
- Variable 0 to +18dB Bass Boost
- Variable input gain control
- Power and protection LED indicators
- Thermal, overload and speaker short protection
- Line and speaker level inputs
- Chrome plated RCA connectors and screw terminals
- Remote subwoofer level control
- Frequency response: 9Hz - 50kHz (+/- 3dB)
- Max power 2 ohm 1200W X 1
- RMS power 4 ohm 500W X 1
- Signal-to-noise ratio 103dB
- THD at RMS output 0.01%
- Damping factor 125+
- Dimensions (9-1/8" L x 10" W x 2-7/16" H)
ESPECIFICAÇÕES
- Low pass crossover on CH3/4: 120Hz (fixed, 120Hz)
- Frequency response: 12Hz - 22kHz (+/- 3dB)
- Max power 2 ohm 100W X 4
- RMS power 4 ohm 50W X 4
- Signal-to-noise ratio 90dB
Subs
CVR12-4DVC 90.00
TR5512-04 115.00
TSW 308D2 63.00
Hoje à(s) 9:15:59 por Gerald
