BOM DIA PESSOAL
TENHO 4 RODAS RALINHO NA CARAVAN, MAS ACHO QUE NÃO SÃO ORIGINAL, POIS COMPREI AS CALOTAS E ELAS NÃO ENCAIXA CERTO. NA RODA NÃO TEM NADA DA GM E SEU NUMERO É ET-27 E REPAREI QUE AS DA GM É PF-27.
TENHO QUE TIRAR UM POUCO DA CALOTA PARA ENTRAR, MINIMA COISA, UNS MILIMITROS E DIAMANTAR ELAS, SERÁ VAI DAR CERTO?
OU TENHO QUE TROCAR ELAS
ALGUEM JÁ VIU ESSA RODAS PARALELAS?
