por Nictheroy 4400 Qua 11 Ago - 13:15:41
Do site da Summit, dentre outros:
Proform Parts 67081 - Proform Street/Strip HEI Distributors
Distributor, HEI Street/Strip, Magnetic Pickup, Mechanical, Vacuum Advance, Red Cap, GM, 194, 230, 250, 292
Part Number: PRO-67081
$189.95
Summit Racing SUM-850043 - Summit Racing® Blueprinted HEI Distributors
Distributor, HEI, Magnetic Pickup, Mechanical, Vacuum Advance, Black Cap, Chevy, 194, 230, 250, 292, Each
Part Number: SUM-850043
$189.95
Davis Unified Ignition 617211BK - Davis Unified Ignition GM Racing D.U.I. Distributors
Distributor, HEI, Vacuum, Mechanical Advance, Black Cap, GM 6-Cylinder, Each
Part Number: DUI-617211BK
$369.00
Davis Unified Ignition 61720BL - Davis Unified Ignition GM Street/Strip D.U.I. Distributors
Distributor, HEI, Vacuum, Mechanical Advance, Blue Cap, GM 6-Cylinder, Each
Part Number: DUI-61720BL
$305.00
Davis Unified Ignition 617212RD - Davis Unified Ignition GM Racing D.U.I. Distributors
Distributor, HEI, Mechanical Advance, Red Cap, GM 6-Cylinder, Each
Part Number: DUI-617212RD More Detail …
$369.00
